Chain and Sprocket for 99 Busa?
bpjones
Well, it's time for a new chain and sprocket for the 99.....
Any consensus on what most people are riding?
What's the hype about going up to a 43 tooth sprocket?
Is it standard to change out the front and rear sprocket at the same time?
Loking for brand/item and price recomendations here.....
Most people change the chain and both sprockets plus the cush rubbers at the same time. I went with an EKZZZ and JT sprockets from Charles at Street N Track. Quick delivery and exactly the right parts.
i went 16-42 but havent had a chance to ride it. if you just decide to go up in there rear its always a good idea to get a stock tooth aftermarket sprocket in the front
Thanks for the info guys.....as I understand it, stock is 40/17
What's the advantage/disadvantage of going to a 43?
Also I'm 225lbs and regularly hit 150-165mph on the commute....(not for long mind you...too many Moose way up here in the Great White North)
Does that have any impact on my chain/sprocket needs?
BJ
alot will say go up in the rear..easier on the chain.
Lower gears = little less gas mileage, quicker acceleration,spin tires easier,..etc.
I went 16t in front and like the way it pulls...just ordered a 42t for the rear I will put on prolly at mid or end of Summer with a new chain.
If you are cool with how it pulls now and have no need for a quicker acceleration..leave it stock 17/40. :beerchug:
16/42 is the way to go.....your mileage will go down alittle, but the fun factor will go off the scale :thumbsup:
Its the single best mod you can do to your bike, and its also cheap and easy....thats a hard to beat combo :beerchug:
