Don't know if it's mentioned, but rotate the rear wheel during adjustment because there's tight and loose areas.
That's the dirtiest Busa shot I've seen.
Ahhhh, you haven't seen a Charlesbusa bike shot yet!(dadofthree @ Jan. 21 2007,15:04) That's the dirtiest Busa shot I've seen.
Although this might be true you do have the most dirt.(Wag @ Jan. 20 2007,10:40)I'm actually highly proud of the fact that I have NO chicken strips.(Over_Easy @ Jan. 20 2007,08:30)+20 Good God man, have some pride.(GIXERHP @ Jan. 20 2007,07:22)+10(heavybusa @ Jan. 20 2007,04:56)Good stuff, now go wash your bike
Ride it. Don't wash it!
--Wag--
Well, seems like I read something about that because I loosened mine and still had/have the same problem. When I torque it to 72.5 it still tightens back up. I think I must be doing something wrong still.(hottrodd7 @ Jan. 20 2007,07:41) Yep--you're right. I was having the same problems and then I loosened the bolt. MAGIC--it worked!!! I don't remember reading anything 'bout it!
GPW has a good price on them..(Wag @ Jan. 25 2007,08:11) What's the part number for that item? I searched everwhere for it and could NOT find it.
--Wag--
How many miles do you have on that chain?(Learjett @ Jan. 29 2007,07:02)Well, seems like I read something about that because I loosened mine and still had/have the same problem. When I torque it to 72.5 it still tightens back up. I think I must be doing something wrong still.(hottrodd7 @ Jan. 20 2007,07:41) Yep--you're right. I was having the same problems and then I loosened the bolt. MAGIC--it worked!!! I don't remember reading anything 'bout it!
I have just over 6,000 miles on it and the bike(Wag @ Jan. 29 2007,22:23)How many miles do you have on that chain?(Learjett @ Jan. 29 2007,07:02)Well, seems like I read something about that because I loosened mine and still had/have the same problem. When I torque it to 72.5 it still tightens back up. I think I must be doing something wrong still.(hottrodd7 @ Jan. 20 2007,07:41) Yep--you're right. I was having the same problems and then I loosened the bolt. MAGIC--it worked!!! I don't remember reading anything 'bout it!
--Wag--
