Easy peasy! Do you have the shop manual? If not, download it.
Take your time, read the instructions, realize the pads are a set and side specific. DO NOT Depress the brake lever when the pads are out. You may have to spread the piston in the caliper to make space for the new pads to fit properly. Your best bet is to have someone there with you that has done it before for guidance and support. If I can do it, anyone can! You may want to bleed the lines after the new pads.
