Changing oil in busa 08&09
For the third time. If you use the replacement hose you don't have to take the line of to change the oil.
Posted via Mobile Device
I have the Yosh full system and I remove the bottom oil cooler bracket and take the filter out between the center 2 headers..
I don't know If it will on the ti force either. You have the race system?
I have a 4-2-1 race haven't changed since I installed but theirs not much room around. Can't remember but you mayy be able to undo the line from cooler to gain clearance.
Who installed the exhaust? You may see if you could get a little adjustment out of it.
See what they say. If they sell it they should support it.
May help if you loosen oil cooler itself and try to squeeze filter out between it and headers.
The oil cooler has a flex line on it.
I have Brocks exhaust and it helps to loosen cooler mount bolts.
I then take filter out thru first and second headers on right side
of bike and then out from in between oil cooler and header tube.
I have Brock's AH and the quickest way i've found to get the filter in and out is disconnect the exhaust can from the exhaust mount and it gives just enough room to slide it out. I didn't want to jack with the oil line if didn't have to. My filter just almost comes out but not quite, disconnecting the can allows that 1/8 inch or so to squeeze it on out of there. Hope this helps
Do you have the TIFORCE exhaust on your bike
Do you have to take both panels off to get to the oil cooler bracket
