Im changing to a set of 208's the rear's easy fronts a little bit of a problem. Is a stand the only way to stabilize
Just to note......... it will not work on lowered bikes.You can get a Pit Bull stand that supports the bike from the steering stem, freeing up your front end and forks. I replaced my forks spring using it. works great - pricey though.
Cougar
I have a real hard time getting the pitbull stem stand on my none lowered bike, nor can I get the wheel out from under the fender without unbolting then letting the air out of the tire...I resorted back to my engine hoist and straps around the frame behind the steering stem....Just to note......... it will not work on lowered bikes.You can get a Pit Bull stand that supports the bike from the steering stem, freeing up your front end and forks. I replaced my forks spring using it. works great - pricey though.
Cougar
