GaronjaM53
I took out the ECU just to check if anything would change which didn't at the end, I am aware it won't fix anything. I don't have a manual as far I know, but there's a manual online anyways. about the other things that can interrupt the communication, where's the ignition fuse located? Is that the one under the seat? Because that has been swapped just in case even tho it wasn't blown. And it still won't fire up. On/off kill switch has been swapped and lubed up. Connections are not a problem for the kill switch either because I got new wires for it anyways too. Side stand switch and tip over switch is a good start to check it. ThanksDo you have a manual?
There is a section in the manual that talks about "CHEC" and what causes it to be displayed....
It says to check the wiring harness between ECM and speedometer couplings...
Removing the ECM would not resolve the issue as the "CHEC" display indicates there is no communication with the ECM....
There are a few things that interrupt that communication...side stand switch, tip over switch, on/off switch, blown ignition fuse
