I'm not opposed to that, but it would still be steel. That weighs more than aluminum.Weld it.
What is the Ring? The 214 ape part is same as Brocks. I like Jay better than Brock.I debated this for long time I cheeped out and bought the ring.
Bite the bullet and get the hub!Spoke to Pat @ APE hub is lighter as no bolts used. Hub is a wearable item for those that didn't know. How much lighter is not known.
APE hub has oiling holes. Not all makes hubs have oil holes. I'm not sure if a gen 2 hub has oil holes, and neither did Pat.
.What is the Ring? The 214 ape part is same as Brocks. I like Jay better than Brock.
Here is a photo of the two parts. Middle, and lower of page.
This is the ring I was referring to and have been considering
if you are using your bike more for cruising, aim for the lock ring.This is the ring I was referring to and have been considering
Multistage Clutch????how about replacing everything with a mtc gen2? its pricey but ure spending money on the bird now anyway.... and once its done... its done.... it an unbelievable clutch//// mine works just like a traditional clutch when I want it to.... its one of the most amazing mods on this bike.
yes... I say this because c10 has a lot of money invested into his bike lightening it up and he probably has plans for the bike down the road anyhow...……… one less thing to pay for later on.Multistage Clutch????
I have friends with that modification made in their busas and let me tell you it's worth it. With that mod the Engine awakes in an incredible wayI hung up my drag racing days. It's for weight loss. Also to dump the back torque limiter.
HI. I am using the MTC Gen 2 clutch. You still need the inner hub and the outer cover that you can get in carbon fiber!I hung up my drag racing days. It's for weight loss. Also to dump the back torque limiter.
