RedBull
HI .
I am using the
MTC Gen 2
clutch . . .
You still need the inner hub
and the outer cover that
you can get in carbon fiber !
HI .
I am using the
MTC Gen 2
clutch . . .
the mtc complete assembly I believe comes with a billet inner hub.My mechanic recommends that billet APE hub for my application also , I will be getting one soon .
The best and fastest bikes in the world right now use this GEN2 multistage ENGINE-DRIVEN lockup clutch.... and the best part about this clutch is that it is COMPLETELY streetable… it will function just like a stock clutch.... EXACTLY like a stock clutch..... only difference is that.... If I rev this bike up over 4 grand from a dead stop... then just THROW the lever.... IT SLIPS ITSELF.... allllllllll the way almost through 1st gear aand progressively locks up.... with the throttle pinned... the clutch makes it look like I REALLY know what im doing.... I just started doing this at the end of the season... it is UNBELIEVABLE.... maybe @POWERHOUSE can explain exactly how it works.... it is engine driven...………..... trick stuff FOR SURE.... full slider clutches are not streetable…. this clutch is 1000 percent street friendly.... it is truly an amazing piece for sure.. im more Impressed with this clutch than u can believe..... shift into second gear and it is a stocker again.... and if u put it in first and dont rev the engine beyond 4 grand from a stop... it is JUST like a stocker..... I was beyond impressed.I got told recently that a full lock up clutch , say like a trick fully adjustable Hays , you can't just grab the clutch after full throttle in a full gear run , that you have to let it ( motor ) run down to low revs , before re engaging the clutch to slow bike . Is this correct , and how do you compensate for street ridden bike ?
At what cost?The best and fastest bikes in the world right now use this GEN2 multistage ENGINE-DRIVEN lockup clutch.... and the best part about this clutch is that it is COMPLETELY streetable… it will function just like a stock clutch.... EXACTLY like a stock clutch..... only difference is that.... If I rev this bike up over 4 grand from a dead stop... then just THROW the lever.... IT SLIPS ITSELF.... allllllllll the way almost through 1st gear aand progressively locks up.... with the throttle pinned... the clutch makes it look like I REALLY know what im doing.... I just started doing this at the end of the season... it is UNBELIEVABLE.... maybe @POWERHOUSE can explain exactly how it works.... it is engine driven...………..... trick stuff FOR SURE.... full slider clutches are not streetable…. this clutch is 1000 percent street friendly.... it is truly an amazing piece for sure.. im more Impressed with this clutch than u can believe..... shift into second gear and it is a stocker again.... and if u put it in first and dont rev the engine beyond 4 grand from a stop... it is JUST like a stocker..... I was beyond impressed.
2k +/-At what cost?
Are the NLR clutches better than a hand slider? Or better value for money?There’s no need for a $2k clutch on a stock street bike. Clutch mod is really the only thing that’s “needed”.
Street strip turbo bikes I use to always use 2 stage lock ups, but ever since the NLR boost clutch came out, those have been installed on just about every bike to leave my shop that required a clutch. I’m going to try one on my grudge bike before I order a slider for it.
Round about $2300-2500. c10 I put Carpenter setup on mine and it works just like the Brocks/APE unit just not as fancy. Now pay the extra money if going for weight which is a major for you. Will say the Carpenter is well thought out simple & flat out works which is why I purchased & was very impressed .At what cost?
Holy moly, I will pass on something like that for now.Round about $2300-2500. c10 I put Carpenter setup on mine and it works just like the Brocks/APE unit just not as fancy. Now pay the extra money if going for weight which is a major for you. Will say the Carpenter is well thought out simple & flat out works which is why I purchased & was very impressed .
That sounds like the best potential street setup , and not such a killer $ hit !!
hm. gonna have to research that sucker.
