OK, so I get the clutch mod done and everything buttoned up. I start the bike, drop it in first, let the clutch out and, holy ****, the bike doesn't move. I was like WTF is going on. So I took it back apart re-read the instructions and found the problem pretty easily. The instructions weren't really clear on how hard you need to push on the pusher to get it in all the way. Pushed the pusher ALL THE WAY in, quickly put the clutch cover back on and put the casing on. Started it up, dropped it in first ,let the clutch out and I'll be damned it rolled forward just like it should. I was a little scared when it didn't move but it was a good learning experience. The bikes almost done, now only three more months til I can ride it!
Oh, and thanks Biggdaddy, I made a tool to hold the clutch hub and it worked great! What would I do without the ORG?
Brett
