OK I got it figured out and have the clutch put back together using the spacers provided in the kit and everything is working fine. First problem was I should have read the manual more carefully before taking it apart and second I should have paid more attention when put it back together. Here is where I screwed up and what I found.
- There are different sizes of drive discs (fibre and metal). There are 8 fibre discs @ .12 and 3 @.15, of the metal discs there are 7 @ .08 and 2 @.090.
- I mic'd the discs and found that I had 3 of the metal discs that were .09 instead of 2.
- I didn't pay attention to the disc sizes and did not assemble in the order prescribed in the manual. (I actual took a roll of the dice and put the third metal disc that was .09 on the outside with the 2nd of the .15 fibre discs when I put it back together this last time.)
- When I was assembling the discs in the clutch basket I did not put the last and outer most .15 fibre disc in the other slit in the clutch basket as described in the manual and which I should have noted when I took the clutch apart.
Anyway, through all the trials and tribulations of a simple 15 min. modification I spent at least 6-8 hours trying to figure out my screw up. My thanks to everyone for giving me the benefit of their experience (especially Mike1180)and I hope that this posting might help some one else.
