Hayabusa133
I have a 2006 Suzuki Hayabusa with approx 31000 miles on it...I ride daily, a bit on the aggressive side, a bit of road racing and visit the track sometimes twice per month I'm starting to hear some noises coming from the inside the clutch cover...And the bike is really hard to launch (jerky/ will stall if I try to launch at a high RPM)...I did some research and found out that I might have to change my clutch basket, clutch plates and clutch Hub...
What are your suggestions???
What could be causing my problem???
should I replace the Clutch Plates (Fibers and Steel), Clutch Basket and Clutch Hub with OEM Parts???
Or are there any better High performance Clutch components out there???
Thanks
Mark.
Thanks
Mark.
