JeffW, where did you get that from?
That idle raiser lever does nothing but operate a small separate cam that in turn slightly opens the normal cam operated by the throttle cables.
Just take a look at the mechanism on the right side under the tank just visible. Even when checking this fast idle mechanism with everything blocking any view removed I can't for the life of me see how this has anything to do with ignition timing.
Seeing how good the Busa starts even in the cold and that I prefer to slowly warm-up my Busa while actually riding instead of leaving it unloaded on higher idle for a while I'm even going to remove that whole fast idle thing (removing things from my bikes that have no use for me is only one of my more serious fetishes).
