the stock pump only flows 14.7ghp at 43psi.just from doing dyno test my bike would fall off about 12-15hp from 9200 to redline.which does not help at all at the dragstrip or running on the road. there are a few people who still don't beleive in the bike how fast it is.i now have a system that flows 30ghp at 45psi with return style regulator that is adjustable. i have a mallory 60fi pump, big efi filter, pressure gauge, steel braided lines. i spent about 475.00 but i have enough volume of fuel to push 350hp.you know turbo,1500cc w/n2o,etc. you also need to bump pressure to 45psi.once you have modified airbox,highflow pipe,and getting bike to stay cool.if decide to go with after market setup be sure you have a 40 micron filter before pump and a 5 micron after .it will easier to service
