Go to my link for the install on the busa! On my 09 1k yes plug and play, but 2 things!
1# I shorted the wiring on both the busa and the 1k. Less mess with the wiring when securing it! (there harness I shortened!)
2# I had to remove the red wire and black wire for the DDM hid connector and swap them on the 09. It was aired backwards. Easy fix.... take a pick and lift the lock on the pin and remove from on side to the other!
you need 2 ballasts! one for low beam and one for high beam. i put one on each side of the head lamp assy. in the tight spot above the ram air tubes. Posted via Mobile Device
