DIP switch for 01' Busa
wardie
Has anyone installed a newer headlight high beam switch (left handlebar) which would have a DIP switch which enmables you to pull the high beam on and off at will without flicking the high beam togle switch on? The newer Busa's have them and I'd like to see what's required to convert to newer switch gear. Wardie
Honestly I think they should be wired the same, if not you should just have to trace a couple wires and rewire the other plug on there.
mine has the switch, but that switch is now my nos button....it is wired as a momentary contact and ties directly into the high/low switch
