So, I dropped off the hayabusa at the shop with a peculair problem.
I discovered that the coolant resevoir was empty, filled it up, went for a short ride and the next day it was empty again. I dropped it off at the shop a couple of days ago, and my mechanic filled it up. He calls me up to say that he found it empty the next day. Hmmm.... He said that he checked the oil and the exhaust and it isn't there. There was no evidence of leakage (ie no puddle) any of the times. I had checked the hoses/tubes (they were fairly loose) and tightened them. I thought maybe I was spraying coolant all over the road. My mechanic said his next step would be to do a "leak down test".
Also, before I purchased the bike (used), the previous owner had replaced the tail pipes. He said that the radiator had to be removed to do so.....
* Any thoughts on what might be the issue here? *
Thank you very much!
