I showed 158 and 95 when I had my full Akrapovic Race dyno tuned. Look on their web site and do some research. Without motor work you don't find big HP numbers with Akra pipes. I thought the EVO was better than the Race? Things are much better now...Have a 2005 . Removed pair valve put a full aka evo system. Put on a pc111.Took it to be dynoed he said he put a custom map. Only showed 156 hp and 95 torque, What did I do wrong those numbers are barely better than stock.
Any suggestions please
WAAAAAY low.Have a 2005 . Removed pair valve put a full aka evo system. Put on a pc111.Took it to be dynoed he said he put a custom map. Only showed 156 hp and 95 torque, What did I do wrong those numbers are barely better than stock.
Dynojet maps are USELESS for YOUR BIKE and YOUR APPLICATION. B/C it is tuned to THEIR (DYNOJET'S BUSA) bike and not yours. Every Busa is gonna be a little different. You have to custom map for BEST Results!!So you think I just need a new map.I was thinking maybe it was the pipe .
Before I had it dynoed I had a map from Dynojet for my system.
The so called custom map feels no different.
I have the SAME set up with a custom map...162 HP 100 TQHave a 2005 . Removed pair valve put a full aka evo system. Put on a pc111.Took it to be dynoed he said he put a custom map. Only showed 156 hp and 95 torque, What did I do wrong those numbers are barely better than stock.
Just the reason you need a BEFORE and AFTER run. Unless you have this, you really don't know if anything is wrong with the additionsyou should have dynoed it before the mods. you bike could have had a problem before the mods
Ditto.....Somebody is doing something wrong... Get a better map. PM quasar or J. cheese... Although I don't know if Johnny Cheese is doing them anymore. If you want a Quasar map go to sh.org and pm him. Like smoke215 said I ran 156 bone stock.
