So, I've had the '08 for about 750 miles with absolutely no problems (besides spongy brakes)... until today, the day I finally found the time and willingness to part with my new toy for service 1.
Today, on the way to the shop, I discovered when I needed to down-shift... it wouldn't.
No matter what gear I was in, it would not shift to any other gear beneath it. The display just showed that horizontal line like: ----- Then, if I slowly let out on the clutch (gear engaged obviously), it would downshift to the next lowest gear, updating the display. I could do this over and over 'til I hit 1st, then head on my way. Kinda scary with angry zealot drivers raging behind you.
So, I sorta felt like I was in the bonus round of the typical can't shift into first from neutral problem, except the regular trick of letting out on the clutch and bringing it back in wouldn't work of course because, the clutch was engaged.
Luckily my shop was just around the corner. They said that I need to make sure I down-shift through every gear to prevent this problem? What? I down-shift as much as possible, but not always every gear and not all the time... don't always have the time, ya know? One guy said it was bc they put thinner oil in at first to help break the engine in?
What does that have to do with anything?
Hopefully they get it sorted.
- Pohl99
- Pohl99
