Your times depend on a lot. You're weight, ability to launch and stay in the throttle, and of course gearing.
If you are around 200lbs, aim for a 60ft time of about 1.7 with a quarter mile time in the high 9s. Your speed doesn't really matter much. Sometimes lower speeds generate better times. You will be in the high 130mph range, possibly the 140s
Good luck and have fun. Also, make sure you have a strap for the front. It will help with the launch.
ET? 10.70-10.20's depending on YOU more than the bike.. I have watched 200hp + turbo bikes run 10.50's
no disgrace in running 10's make sure you get video or post your ET slips..
seems pretty respectable for a fat tire bike (a lot of weight to turn)...My first year running at the drag on a bike....and I went 10.4 @ 136 with 150HP running that big 330 fatty. Like he said.....your make most the diff on what time you will run.
