Mythos
Good compression, that's all. If you turned the motor and the cylinders were compressing or sucking, you can hear it.I put a 14mm wrench on the bolt and manually tried to turn it which had made a hissing sound of pressure releasing. I don't really know what to do at this point. I don't know what that pressure is, or what it means good or bad. ??? Any recommendations are appreciated.
