ECM / HUMIDITY / SETTINGS
G
Guest
The fuel injection system corrects for intake pressure and temperature, it does not correct for humidity. If you are in a high humidity area you will need to run the system leaner. This is why some lower than stock settings work for max horse power. If you are in a low humidity area then a richer setting should be used. David G
I know what you are saying i am in Tampa Fla,i went with +5 all the way which was to rich because of the high humidty. I end up with 0 all the way across.
