Audiomaker
Hi all,
My basic understanding is that an intercooler cools the super heated air coming from the intake side of a turbocharger.
It is also my basic understanding that the intake side of a turbocharger becomes super heated by heat conducted from the exhaust side.
In a heat exchanger (air/air or air/water), the exchanger is cooled by atmospheric air temps (meaning the air around us).
So more or less, an exchanger (i.e....intercooler) will not produce air temps lower than the outside air.
So far so good?
Ok...
Well that is the same temperature of air that the intake side of turbo is "inhaling" right? On our bikes, it might even be a bit cooler as the air filters are often on the outside of the bike where intercoolers are getting their air flow from closer to the engine heat.
So, my question is.. if the intake side of the turbo were thermally isolated from the exhaust side, wouldn't the air temperature of the post turbo intake air be at near atmospheric, thereby eliminating the need for an intercooler?
If the answer to this question is "Yes" (which I think it is), then why the heck are they using cast iron, steel and aluminum as the mating parts between the intake housing and the exhaust housing, and also a metal connection between the exhaust wheel and the intake wheel?
Unless I"m looking at the cut away photos of turbochargers wrong, the vast majority of heat transferred to the intake housing comes from the metal connection between the two housings, and by the shaft.
Couldn't one use a non heat conductive material for these parts? There are indeed materials that are rigid, machinable, sturdy, and don't conduct heat. Think of Ebonite frying pan handles... you can put these in the oven at 450 degrees for hours but they are very poor heat conductors.
It just makes sense in my head that if one were going to eliminate heat from the intake air, then the best place to start would be insulating it where the air first becomes heated instead of trying to cool it after the fact.
Thoughts?
Sean
So far so good?
Ok...
Thoughts?
Sean
