sorry forgot to include turbo's don't like water if you if inject into the compressor wheel. The water will erode the wheel. If you inject after the compressor housing, no problem.fstbusa,
What is your basis that turbo's don't "like" water injection? It is quite the contrary (assuming you don't inject pre-turbo). As the water cools the intake, the engine, and then the EGT's, it also helps cool the turbo from the inside out since the EGT's are lower.
You also claim that water injection will cause a loss of power, which is then made up when you increase your boost. I can only assume you are thinking that the water replaces oxygen and therefore you will lose power. I agree with that, however, since water can not be compressed, your compression increases (the squeeze in "suck, squeeze, bang, blow), which will compensate for the very minute loss of oxygen.
Let me know your opinion.
Thanks,
Greg
Thanks,
Greg
I don't count increaing your boost. Some people use water to increase boost while others as myself use it as a safety barrier.
I also have dyno experience that water cost by bike about 3-5 hp. No biggie but I've seen it first hand.
<!--EDIT|fstbusa
Reason for Edit: None given...|1119173873 -->
