I've been running the bike in the garage to create logs with the LM-2 and make some final checks. I noticed the bike sometimes smokes the first couple minutes, and depending on how long it was running, oil enters the exhaust right after I shut it off.
I'm using the Emtes Oil Scavange Pump and I'm sure the pump and all the oil lines going to (1/4") and from (1/2") the turbo are correct, including the outlet vent hose (1/4") required by the Emtes pump. I also have check valves installed at the turbo both at the inlet and outlet which should prevent this sort of thing.
Tonight I replaced the vent hose with clear hose. No oil backed up into the vent hose until I shut off the bike. At that point about 7" of the vent hose filled with oil within a minute or so. The level did evenutally drops to 5" or so but that missing 2" is probably in the exhaust pipe. When I start the bike, the oil in the vent hose immediately gets sucked in by the Emtes pump and everything is fine until I shut off the bike, at which point the process repeats itself.
I'm thinking that when I shut off the bike the pressure in the oil line going to the turbo takes a while to drop, which keeps the check valve from closing right away, allowing additional oil to continue flowing into the turbo. Having a high volume oil pump gear could be very well adding to this problem, if not the cause of the problem.
Okay, this is somewhat related to another post I made about a restrictor in the oil line between the check valve and the turbo. Only now I'm trying to figure out if the restrictor will fix the problem or if I need another check valve that requires a higher opening pressure.
If anyone has any thoughts, go for it.
