Hi. Like I said use a Gen 1 block put in stainless steel intake vales and Inconal exhaust all 1mm larger turbo cams Carrill rods some use a better crank. In the trans get a HD output shaft output shaft support by Robinsons Industry with a bilit lower 1st gear. Pistons ??????What would you do to your Gen 3 engine to handle the extra power from a turbo / supercharger kit?
All Gen 2 engine performance parts fit Gen 3 engine?
Or they need to be custom made at this moment?
Supercharger or Turbo? What fuel?Street bike
Some wots from time to time
372 bhp
well... TTS says that they have a kit(intercooler) that will provide sufficient cooling for 370HP on PUMP....... i guess that depends on your definition of sufficient becuase its NEVER been tested in a mile long pull or any land speed testing. This doesnt seem to concern other people though.... maybe u could do the testing? As far as the motor goes you are probably gonna wanna do a basic forged motor.... pistons/rods/springs/studs.... and you are gonna be at about 4000ish bucks alll in to completely forge the motor.... minus the crank(the crank takes about 700HP... not needed)... For what you want.. u dont have to send the cases out to be machined for 1/2 inch studs................................. ORRRRRRR u could do a a a spacer motor with a top end kit that drops compression in preparation for boost. It dpeneds how committed you are.... its easy to spend alot of money. For 370HP i wouldnt realistically leave a stock motor in it. You are asking for trouble. With a forged motor... u could sleep alot better.Supercharger - 100 octane - pump gas
I don’t think anyone has really pushed stock Gen-3 internals but old thinking is typically 320-350hp before rods check out and 400 for pistons. Many thought titanium valves would be an issue but many have run them over 400hp without issue so it’s the valve springs you would want to watch.Street bike
372 bhp
he street rides it.... hence my harping on the air/air intercooler in the blower kit he is considering. A good turbo kit is always worth its weight in gold and u cant get any better than a kit with a 2 year warranty(RCC). The intercooler in the RCC kit on pump gas has been tested to death. pump gas and that air/water intercooler truly is the gold standard.No need to go to a Gen 1 block. Keep your block.
Keep valves oem size, just swap to stainless, put heavy duty springs in the head.
The valves and springs are a must for sure. The remaining is dependant on how much you wanna push. If you're going beyond 15psi I'd definitely do the pistons and rods.
Back cutting the trans is really a good idea if you are going that far. If you are taking it to the strip and launching it off the 2 step, then do the HD output shaft on the trans. If you're just street riding and roll racing, then don't waste your money on it as it's not needed.
Your crank is fine, you don't need to upgrade it. Lots of huge hp bikes running the stock crank (me included).
Keep it simple, lots of people will tell you that you need this and that, but alot of the time you don't. You just need to know exactly what YOU are gonna do with it and that will dictate what you need.
Thank you big time for your message!No need to go to a Gen 1 block. Keep your block.
Hey Busa,Thank you big time for your message!
What pistons/rods/springs/studs/valves should I get and from where?
If you're interested, I've got quite a lengthy build thread with photos and exactly what I used for reference in the Turbo section.Thank you big time for your message!
I live in Europe and for the moment I don’t have a builder for this project.Hey Busa,
There's lots of options and people will recommend different brands for different reasons. I'm going to recommend a brand and for sure someone will chime in and say x brand is better. But in all reality for what you are going to use it for, you can't go wrong with any of them.
Pistons I'd go with Wossner 9:1 turbo pistons. They are stout, built well and take a beating with no problem.
Rods, I'd go with the same brand... Wossner.
For valve springs go with APE valve spring (65 lb springs)
For studs I'd just go with an APE stud kit. No need to go 1/2". Just go with the stock 3/8" size. Make sure you order washers as well (explained in the info section on them as gen 2s washers don't come off the oem head studs)
For Valves just go with APE stainless steel valves, or Vance and Hines oem size. Kibblewhite also makes nice valves and I've used them. You could get fancy with inconel but definitely not needed.
One more item is a cometic head gasket (oem thickness).
If you're in Canada, I'd just order the whole lot from Richard at RCC Turbos as he typically has most of the list. May have to wait for a couple items. If in the US, just go through Schnitz racing. They have it all.
Now this is of course if you're going to do it all yourself. If you have someone do it for you, then you need to be clear with them with what you want in the list. As for a builder, I'd send mine to DME Racing If it were me. Mine, I built myself as there's nobody near me to do it.
I will check for sure, thanks!If you're interested, I've got quite a lengthy build thread with photos and exactly what I used for reference in the Turbo section.
This is exactly what I am looking for.Also, the above info would be the least damaging financially...lol. You could go all out and get all sorts of custom one off stuff built, drill the cases for bigger studs, different valves, guides etc...
But for what you're using it for, this is the the easiest and reliable approach.
manufacturers use the cheapest garbage they can get away with... its not that easy. Maybe a little boost... but no manufacturer uses rods and pistons ready for any type of big boost... (double digit boost levels..)From everything I've read, the engine in the gen 3 is built more robust than the other generations, how much internal work would it need?
From what I read it almost seems like Suzuki built it for boost.
Yep, and at the moment Woolich unlock doesn't have the option to change the 1bar map sensor to a 3 or 4 bar yet, so I'm confused on how the ECU knows how much fuel to add when under boost. I wouldn't touch any boosted option until Woolich adds a boosted option for the gen3 or you manage to get a MoTec ECU swap.manufacturers use the cheapest garbage they can get away with... its not that easy. Maybe a little boost... but no manufacturer uses rods and pistons ready for any type of big boost... (double digit boost levels..)
