IG.
Running out of ideas - need a little help.
Symptom: momentary loss of power over bigger bumps, smaller bumps are OK. No FI light ever when this happens (i.e. no code).
Recent work: had C24 problem on starting the bike - cured by cleaning coil connectors - never shows up after the fix.
Troubleshooting done:
1. Shorted the kickstand switch. Rode. Still a problem.
2. Put the bike on rear stand, lifted the tank, started, put in 1st gear. Pulled and banged on PC, ECM, battery, all connectors surrouning them, connectors under the tank (i.e. fuel pump connector, connector to injectors). Not a hiccup. I will repeat this exercise again, just to make sure.
What else? Connector to the instrument cluster, sidestand relay, kill switch, TO sensor. Not sure...
