Kiwi Rider
Lookin' soooo good, makes me wanna pull my engine and play with big bore this and turbo that lol.
Please be sure to record the step by step advancements in hi-res pics!Torqued everything down last night, installed the front sprocket and cover. Today I'm going to get the throttle body and gas tank back on. Lots of electrical stuff to plug in. I'll try to get the exhaust done today too. Should be able to finish on Sunday. Nothing planned for the day.
Well some comedy. Filled it up with fluids and went to start it. Zzaaaappp. Bright flash. Nothing. Apparently you have to have the engine ground connected. Lol. Long day.
Fix the wiring and it cranks over once and the battery was dead. Yes I’m special. I could have had it charging for a long time but I’m an idiot.
Good part is nothing is leaking yet. Hahahaha.
Opps!Well some comedy. Filled it up with fluids and went to start it. Zzaaaappp. Bright flash. Nothing. Apparently you have to have the engine ground connected. Lol. Long day.
Also having some charging issues. May be due to last nights lightening storm.. lol
Well. First ride didn’t go so well. Made it about 5 miles and I’m stuck on the side of the road. Threw an FI code, shut off and now I’m waiting to get picked up. Doesn’t sound good. Something sounds loose. Fml
Made tons of popping noise, rpms went up down up down all over the place and she shut off. Won’t start
Same line of thought here also,,, something isn't right,, and not making sense,,,I wouldn't be opposed. Or give me a time and I'll get a truck and bring it up there.
I've tried almost everything I can come up with. Short of replacing parts to see if something works. Tempted to take off the stator cover and have a peak inside. Pulled the starter just to make sure it wasn't stripped or something. Was fine. Wish I had another bike here to test electrical parts.
