or you can be like me and want about 200hp or as close to it as possible without taking the engine down or doing any gearing. i wanna know how much i can get out of doing only slight mods and bolt-ons. and i dont want to go 4-2-1 exhaust because i dont like the looks. and i dont want to lose the top end because of the whole, "its a busa and my top-end's higher than yours" thing. i want it to feel like a crazed beast on roll on but still say i can still beat anything out there on top end...or close to it...
WOW Yoda, You are asking for a lot. Im with you though on the exhaust. I want to stick with duals. So an after market pipe is pricey. I will stick with stock and my yosh slip ons that dont do any thing for power BUT gives it a nice little grunt sound. Hell if they were to loud I would of put the stock mufflers back on. I know loud pipes save lives BUT i would rather be stealthy. I'll sacrifice the extra 10hp for now.
OK, as far as more power and low money, you can go with the intake cam on the exhaust side and either get another intake or run stock. I would also add higher compression pistion and a mild port. From what I have been researching. If you just save some money and open the motor once. GO WITH A 1397, mild compression, ported head,cams. If you need a crank add a 08 crank to bump it up to a 1441. Most of the builders on here have built them and make good numbers. Very streetable and run for thousands of miles with no problems. No over heating and no need for 2 batts. Depending where you live ,i'm sure I have talked to the builder near you. I have talked to almost all of them from east coast to west coast. They can all build a good 1397 with good power for the street.
With what ever you pick you will need something for programing the fuel. Weather you choose a pc3 usb or just get yours reflashed. You will want to open the air box up too, with the small air box mod.
If you watch the busa forums you can get good used stuff for your project. Hell sometimes you can get new stuff for used prices.
As far as the regearing, YES you will accel fast and the wheel comes up alot easier BUT when you just want to cruise your rpms are higher than stock in sixth gear. I went with just a stock front 17 and 42 in the rear. I get the vibrations at cruising speed and it eats the fuel more. Not sure if I like it. I just deal with it. I was wondering if I should of tried a 43 in the rear.
OK so after all of this. If you want to accel quick experiment with the sprockets. You can find them used and cheap on the forums.Step it up to cams OR cams and higher comprission mild port. Realy step it up and go with 1397 ,cams , port.
Sorry for rambleing.
