Engine Mount Thrust Adjuster Tool
Zoinks!
Hey guys, I'm tryin to install some race railz on the busa and the rear mounting point uses the rear, upper engine mounts, but I don't have the tool to loosten the thrust adjusters on the nuts. Where can I get the tool? Does the dealer sell them? Can I get em somewhere else cheaper? Is there another way to get the mounting bolts out? Thanks for the help. I'm getting really frustrated with this. After over a month of waiting for the parts I can't even install em cause I don't have the tools I need!!!
are you reusing them? If not use a brass punch and a hammer and run them off.
The tool you are looking for is called a spanner socket/wrench FYI.
If you plan to reuse them, tap them off as stated and then go get some sockets and a die grinder....a few minutes of work and you can have some spanner sockets that'll work for $5-15.
You can make your own out of a couple of sockets and a dremel. 16mm socket and 22mm socket. Hold them up to the bolt/nut head and use a sharpie to mark them. Then take a dremel and grind them down. That's how I made mine....
Now, if you'd rather spend a lot more, Schnitz Racing sells one...
