Nastee
just crimp together no need for soder.It just shows how to mount the fan to the radiator, did you soder your wires together or crimp them
Take you time if you can strip a few wires/crimp connectors & play with fan placement you will see what little they are overcharging you for. You will know it is done right to not just them saying so! You are going to take your time they are probably going to rush through take the $ then next job as quick as possible to make money. Unless you have someone you trust.
LOL LOL
LOL LOL
You are right my friend tell me what is the best crimpers to use,
Okay looked at fan wire when came home i used wire clamps that you don't have to cut OE fan wire. They penetrate rubber coating cut off 2nd fan fitting it goes in other end of clamp close clamp that's it. Pic is not great but gives idea.It just shows how to mount the fan to the radiator, did you soder your wires together or crimp them
Sorry been up all night/day. Need 2 of these clamps that open like a book. 1 for + the 2nd for - of wire being spliced into. The add on wire + is placed in other closed side of clamp then close clamp which locks do same to negative wires.Is it really that easy
Thanks for all the input and pictures
make sure ure mechanic doesn't use crappy scotch locks or forget to tighten any bolts.Review so far on this mod it's starting to warm up a bit in South Florida hit the stop and go traffic both my fans kick in and cool the busa down before this mod temp gauge would be in the red and would have to get around traffic and haul a$$ to cool her off in the coming months I will know for sure I will keep those whom want know about this mod updated
Just an up date on the fan mod its working like a charm the 2nd fan moves alot of air no more overheating issues in rush hour or stop and go trafficWell it July in South Florida and with the mod I did or had done keeps the busa cool fans kick in before halfway so I am a happy camper
Update fan mod is still working great no issuesJust an up date on the fan mod its working like a charm the 2nd fan moves alot of air no more overheating issues in rush hour or stop and go traffic
Thanks for your help on thisCheck the directions from Shintz to see if you can do. I bought same fan that moves alot of air. My biggest problem was that i tried to use 90 clamps & didn't have fan mounted wide enough to clear & had to get another plastic securing kit as i couldn't salvage 1 of the 4 during remount. If you can push securing plastic rods through radiator fins push on round back snip off extra; splice wire with two round tube connectors replace fuse on left front of gen1 then put bolts back in radiator then yeah that easy. I did not disconnect any lines from radiator or coolant system waste of time.
