Mr Brown
Wasn't asking about yours....No it's still stock
It's on 118. I didn't want to go through the entire fuel system to run e85/e98. I ran e85 back in 2008 on my zx14 mas 330 wheel on 12psi back then, e85 is a wicked bad ass fuel just didn't want to do a complete fuel system with a return style and a 1:1 regulatorWhat gas. I’m not trying to ask stupid questions. Your doing something no one has heard of. BCP has run 10psi at 320hp on a stock motor on e98 and that’s unheard of.
Dude his bike is still stock. I've been following that build since day one and have been talking to Rob about his build recently.Wasn't asking about yours....
Ya I guess so if thats what you want to call it. This poop isnt rocket science. It's a matter of tuning and having the balls to turn it up.So now you're 5 years ahead of Rob in r&d?
Because you obviously dont.What makes you think I don't?
Yeah, you right.Because you obviously dont.
Your turbo and not even running a fuel pump or 1-1?It's on 118. I didn't want to go through the entire fuel system to run e85/e98. I ran e85 back in 2008 on my zx14 mas 330 wheel on 12psi back then, e85 is a wicked bad ass fuel just didn't want to do a complete fuel system with a return style and a 1:1 regulator
She’s in opened. Completely stock he posted in a dif thread than the Lucy build. About how he found the max psi before the valves started to float. And how he was pushing water and during max torque he backed out the power so it wouldn’t push water. I thought it was at 10 psi. I’ll have to try to find it.Don't Lucy have valves or springs?
Ya it has a fuel pump and bigger secondary injectors. Other then that stock fuel system. Like I said it's super simple set up.Your turbo and not even running a fuel pump or 1-1?
No spacer plate or head bolts?Got a gen 1 stock motor with a stage 1 rcc kit on 9psi making 280 whp at 63 inch wheelbase ran a 8.3 at 162 mph. Stock hand clutch with brocks mod and stiffer springs. Clutch was slipping on that pass. Stock motor can 7s with the right set up and conditions.
Thanks killa. I'm 68" 200lbs suited. It gives me motavation! I'm hoping to get into the 7s at 170+ I think it will go 173ish as it sits now but gonna have to wait till March to find out. Oh also hand clutch here too.Got a gen 1 stock motor with a stage 1 rcc kit on 9psi making 280 whp at 63 inch wheelbase ran a 8.3 at 162 mph. Stock hand clutch with brocks mod and stiffer springs. Clutch was slipping on that pass. Stock motor can 7s with the right set up and conditions.
Oh its seen as much as 14psi but it's a bomb at that power, I feel completely confident with it at 12psi. If needed I'll have those two psi as back up on the higher gears IF I need it. Not trying to be the fastest. Just trying to get a 7.99.12lbs?!!!!! Wow! That’s three times what Richard at RCC and most others recommend on a stock gen2 motor. First time I see a gen2 do that in the 8 years or so I’ve been reading build threads on the org, trying to learn about to turbos For when I decide to put a stage1 kit on mine.
I've been 8.62@164 on a 100 shot on it so far it had more in it I just couldn't tame the beast. Was pretty hard to bring that power in. It was making just under 300hp on the nitrous. Best 60' was a 1.32 just couldn't get it to all work together.Bone stock motor. No studs no spacer plate no nothing. Just the turbo kit, ecu flash and a tune on pump 110. Motor came out this winter for rods and pistons.
Did you tune it?Ya I guess so if thats what you want to call it. This poop isnt rocket science. It's a matter of tuning and having the balls to turn it up.
