Yes Frank as far as I know it is stock . i got it from Cycle specialties performance in South Carolina. The dealer dyno'd it and gave me the numbers-Chris Moore is a pro drag racer (suzuki) and said it runs strong and solid.
Mnay itmes were cobbed as far as electronics and plumbing of lines so I have been working on that almost every day. When I get it done I will see how it runs- I am not going to do compression checks or anything right now as it has only 3200 miles -whick i know means nothing -but there is so much to do I am getting overloaded. I have been wanting to call Mr turbo tech line for days but never seem to get to it-i want to get my installation instructions for turbo system and air shifter to double check everything.
I will keep your name for when i need help--thanks Al
If you need help with making sure everything is routed the right way with your turbo system and air shifter you could get ahold of Smithabusa. He is one of the site sponsors and is currently putting a turbo 'Busa together. He would be someone to get a hold of. Good luck on getting everything buttoned up and getting out there for a ride!!
