I am having a problem with my Y2K. Its seems to be really rich but has hesitations as if it were lean below 3K. I have YOSH DUPLEX, FULL MOD BOX, SHORT STACKS,NO PAIR AND ORIGINALLY SET AT 11:45, 0,+5,+10. We remapped on the dyno to +5,+5,0 and picked up 5 hp. Bike hesitated badbelow 3k on the way home but hauled a$$. I set the idle adj. at 12:00 and it got better but still smokes slightly when revving it in neutral, hesitates below 3k and the spark plugs are black! The TPS is at midway at 1150 and top mark at 1650 rpms. All vacuum hoses are connected as are the sensor connections. The fuel return line is is routed per the manual and is not kinked. I think I am going to get hotter plugs and maybe try to return the ecm back to stock settings. Then the machine should be real lean, if not then something is wrong elsewhere. If I cant find it and the help from you guys doesnt find it then the stupid a$$ dealers really are not going to find it and I guess I'll just shoot myself!
