I also found those conversion brackets in a 108mm flavor so you can use the gen2 calipers or any of the gsxr1000 calipers. I think that the way I'm going since the calipers are cheaper then the brembos and for me will work just as well.
I don't do track days and I don't ride super aggressive on the street so gixerhp brembos would be over kill for me. The gsxr1000 calipers are cheaper but still a very good caliper and alot better then the gen1 calipers.
But the ZX6R/14R Nissin's are the best OEM ones that fit right?
Went to go install 08+ Forks and the Nissin Calipers, I ran into this issue. I assume there is suppose to be some sort of spacer? What do I need?
I have read about others swapping Gen 1 forks for Gen 2 forks and brake setups and what I have found doing the research is, to use your Gen 1 wheels and rotors with new setup. You will need to space both your rotors outward 2mm to center them in the calipers. Also Gen 1 has 320mm rotors and Gen 2 has 310mm rotors so you will also need 5mm spacers on both calipers to space them outward aswell.
