@ RedBusarider-
I want to say that I went with JT Sprockets- steel on the rear. I don't remember the exact cost- I want to say around $50 for both sprockets.
I wouldn't say that it is a VERY easy job, but if you have the proper tools and a little patience, it is a doable job. The most difficult part of the job is getting the front sprocket removed. I've heard people say to use an impact wrench, but I didn't have one available. I watched a couple Youtube videos, but this one was the most helpful (actually, I love this guy and his wife- great people!):
BTW- I used a breaker bar to loosen the allen head bolt. I used a 20" breaker bar. Be careful when tightening it, though... it is possible to break the head off while the bolt is partially tightened. That will not be a fun "bunny trail" job. I know this from experience.... broke that bolt right off, and fixed with a bolt extraction kit from Lowe's.
FWIW, the longer I have my busa and work on it myself, the more I see places where the previous owner really cut corners. I was planning to change both sprockets and the chain at the same time (which I did), and found out that the previous owner put a chain on my bike that was rated at most for 600cc. We fixed that, though.
I wanted to go to an 18/36, but I think my 18/38 works for me. While you are changing the rear sprocket, I would definitely take the extra time to check the cush drive as well. Mine didn't need to be replaced, but I replaced it anyway. That job took me about 3 minutes- took me longer to clean my rear wheel before I put everything back together.
There are tons of guys on this site who know LOTS more than I do about these types of things, but if I can do anything to help, let me know. The Youtube video was my teacher on this one, and "Mr. B" does a great job of talking through the process. You could even push play at the beginning of the video and change it out while watching it. The video is over an hour long.
Good luck!
