The main issue that got me into fabbing my own is the length, I wanted sliders that would keep everything from hitting the ground and the LP ones don't quite do this. And strength issue also, mine are definately stronger than LP's due to the stainless hex stock that goes almost full length. And my rears are made the same as fronts, just a little shorter, and you cannot find any rears in sufficient length to keep it all protected. I will post more pics tonight of the entire bike so you all can see what they really look like installed.
Forgot to mention, another benefit (IMHO) is the fact that it only required a 1" dia hole in the fairing and finished outside diameter of the sliders are only 1 1/2" instead of 1 7/8". Rears are also 1 1/2" dia, so they are matching front/rear.
Here is the thread I started back in May, showing just the stainless hex stock and the bike resting on the sliders. Had to test my design in real life !
<!--EDIT|Dr Geekenstein
Reason for Edit: None given...|1089133145 -->
