Front sprocket cover removal
yeah i was a dumbarrssss when i did my 16t front. wanted to move the bike a bit so the bar could get a better bite between rear wheel spoke and swingarm...........pulled clutch lever and BLOOPP went all my fluid on the ground. Good a time as any to replace fluid with fresh so i did
if you plan to do a cover, plan to upgrade your line while you're at it. Pre 04 bikes benefit from the small oem cylinder plug/cover which will help keep crud out of the cylinder in the future.
easiest way to remove the sprocket is put the bike in 5th or 6th and use an impact wrench.
I completely forgot about that....you got a part no. for it?
