Front sprocket swap question
I couldn't care less now. Use it and I hope it works out for you.
Posted via Mobile Device
I have always used an impact and left trans in neutral, never a problem.
On the gen 2 busa's you definitely need to use an impact! I just did and tried every other method till you find out that the damn 36mm nut has lock tight on it! Good luck trying to get that off for the first time any other way! Just my 2 cent on the gen 2 busa.
which way the the front spocket nut turn I know lefty looses, right tighty but is this nut loosen to the right or to the left thanks:whistle:
