I have no pics, but let me paint a pic for you. Bolt to top bolt of each front caliper. I have the clamp on the left side. The strap runs up and over the frame neck between tree yoke and fuel tank bolts (* have it under the throttle cable and under the clutch line so strap is against the frame*). Bring the extra strap up to tree/frame yoke and under the clutch line so the strap is between the clutch line and frame. One hard push down with right hand on throttle bar and pull up on strap with left hand at the same time. Tuck the extra strap across the frame neck and tuck in under the throttle cable on right side of frame and let hang. * leave it hang down but cut off anything over 6 inches left down from the frame when the nose is strapped down. I leave the strap on when riding on street BUT not tightend. Some guys will take the over need strap length and tri strap it the fork instead. lease:Hope you can understand this
