Front Turn Signal Lense Removal
piratediverjefff
Wanting to pull off the lenses to tint and thought after removing the one screw from the bottom the entire assembly might "unlatch" like the rears but doesn't appear to be so.Is there another screw up top somewhere and if so do you have to remove the side fairings and/or an upper panel to get at it?
Thanks,
Jeff
Thanks,
Jeff
Just did a search(which i should've done first:laugh:)and from what i could see there does appear to be another screw(Gen II)and requires pulling some panels to get at.
...crap.
There's aso some adhesive holding them together, so be ready to separate the glue either by pulling or heating.
