Fuel ?????
bosshog
guys...what type of fuel are you running in the k8
regular or premium grade fuel....
thanks
I am still on my second tank of gas but I used Shell 93 octane. I got 45.45 MPG on the first tank full and I'm not sure what the dealership used. I am also being told that about the first gallon you pump is what ever the person before you purchased. Not sure how true that is..
Stickers on the frame and tank say 93 octane, it's all I run, what's another $.80-1.00 per fill on these anyway.
The owners manuals recommendation is:
FUEL
Your motorcycle requires premium unleaded gasoline with a minimum pump octane rating of 90 ((R+M)/2 method). In some areas, the only fuels that are available are oxygenated fuels..
With a compression ratio of over 12:1 you should be running 90 octane or higher. Lower octane fuels are more prone to detonation (ignition before spark also know as a ping). Detonation can be catastrophic at high RPMs. It will also cause an engine with a knock sensor to retard the spark to protect the engine, resulting in reduced performance.
