Lol to that one.
I say if you dont know what kind of fuel to run in your bike you shouldnt be riding. Does your manual say premium or regular? Do you think the manufacturers of your bike had some doubt on the fuel rating when they designed and built your bike? Use regular unleaded unless you bump the compression up in your engine with piston/head mods.
Premium will do nothing for a regular unleaded tune/compression ratio. YOURE WAISTING YOUR DOLLAS!
I use Shell premium.
Lots of detergents, keeps the insides clean.
you win for being the first person this week to ask the gasoline question
double wammie if you ask "what brand is the best"
but to answer your question, you'll only be happy with whatever fuel octane rating you choose to run. It's the best for you.
I run Shell, Amoco, or BP 93 octane premium only. This is also the only gas I run in my car and truck as well. I've done mileage tests in both my car and truck and when figured at cost per mile I actually save money buying premium as I get better mileage with it. Combine that with cleaner injectors and no plugged fuel filters and it is even better. Both my car and truck run smooth and I can tell the power difference between the different grades of gas.
If you read the manual I believe you will find it says 87 or higher. Do your own tests and see what runs best for you. As for me, I'll spend the extra 50 cents a tank to make sure I am running the best I can put in it.
