Wha…….?This isn't good..... | In the News
Never a good thing to have active service personnel engaging in extremism... https://www.msn.com/en-ca/news/us/pentagon-says-about-100-service-members-engaged-in-extremist-activity-in-2021/ar-AAS08Js?ocid=msedgntpwww.hayabusa.org
It’s Redbull, just smile and back up slowly. No sudden moves.Wha…….?
They look better and are lighter. But usually more of a pain to use.What's wrong with the OEM fuel tank cap? Or more importantly, what are the pros of the new one?
so a gen 2 cap will bolt up to a gen 3 but the plastic tank cover has a lip that’s in the way. if any of you care to use longer bolts and trim the lip you can get a green 2 cap to work. the plastic lip gets sandwiched between the cap base and the 4 bolt ring on top.
View attachment 1646371 View attachment 1646372 View attachment 1646373 View attachment 1646374 View attachment 1646376
Thanks @pcs, which part of the front tank cover did you trim, exactly? Trying to figure this out as well.so a gen 2 cap will bolt up to a gen 3 but the plastic tank cover has a lip that’s in the way. if any of you care to use longer bolts and trim the lip you can get a green 2 cap to work. the plastic lip gets sandwiched between the cap base and the 4 bolt ring on top.
On the gen2, yes. Looks like the gen3 has that 4 bolt ring to sandwich the plastic cover between it and the actual gas gap. Gas capIsn't it only 3 bolts that actually thread in, and the other 2 bolts are for looks/other models?
Itself looks like same 3 bolt design.
You are right, normally it says something like, fits hayabusa, gsxs, gsxr, bandit, sv, etc……….since Stone Age.Gsxrs only use 3 bolts too.
I think all the same gas caps fit all Suzuki sport/sport touring bikes for at least 30 years now, lol
