Dafeimao85
Hi All,
Test ride 200 miles already after the filter replacement and bike is in extreme good condition
So me and my itchy ass, I adjusted the gear lever a little bit for a comfortable position. And bam!
I got this gear 1>2>3(3-4-5)>4>5>6 (I got no Tre install)
So apparently at gear 3 maintaining the rpm, the gear did not jump but the display jumping between 3 to 5 (mostly between 3 and 4). As this cause the ecu to apply different maps.
I reset back the gear lever back to the default position and it still act the same.
Does adjusting the lever can cause this problem? Pure luck for me? I search the forum apparently many say this is a common and replace the gear sensor will do the fix.
