Gearing for commuting
MeltDownZ
My newly acquired Busa has been geared down a tooth upfront - so the seller claims.
I'd like to make the bike a bit more commuter-friendly and thought that returning to the stock 17T up front may help smooth out the very torqy feel of the engine in traffic. Trying to short shift 1st at 4-5K rpm is a nightmare in bumper to bumper traffic. Also, should I consider 18T up front?
Not being the mechanic type, I'm assuming to verify the gearing I need to strip off the leftside lower faring and remove some sort of gear cover and count the teeth on the counter sprocket. Is this correct?
Also, if I do re-gear upfront, do I need to replace the chain?
if you dont konw the current gear you would have to open er up and count them. You wont need a longer chain for the front sprocket to be +1 or 18t. 18 would be high but managable. I think 17 is fine but Im not in traffic a ton on my bikes either most maybe 5 lights in a row and then wide open country.
Stock gearing up front (17T) should be fine for commuting.
You are correct, I think there are 4 or 5 bolts to remove, and as I recall if you remove the shifter mechanism, it makes removal much easier.
You'll also probably want to get a Suzuki 17T sprocket as it has rubber on both sides (I don't think an aftermarket sprocket would have this). The Suzuki sprocket will be a bit quieter.
Good luck.
Thanks for the reply's. Just a followup for those doing research on gearing... I went with the 17T, new chain and rear sprocket. After putting on couple hundred miles, I would say that the bike couldn't be anymore perfect for street commuting.
What did you end up installing on the rear tire? Stock 40T or less?
