Bert
Hi all,
Posted this in my intro thread and got no replies ( probably because its in the wrong place tbf )
I am looking to remap my ECU. I have a Ktag ( chinky clone ) and can read/write it. You can pay £75 for a cable but Im tight ( scottish ).
Heres pinout incase anyone needs it...
1 - brown
2 - red
5 - blue
6 - black
7 - yellow
8 - green
I have map definitions for Romraider, and I have an ORI for EU from my bike, and another from an external source - mine is 100% stock. The Ktag appears to read files at 384kb ( padded ) which must be the entire MPC area as the actual data for the deffenitions is 256kb. To read ORI in RR you must first remove the padding, and to write you need to re-pad out the files in hex with FF.
Ive had a play with it, but tbh its well above my level of confidence - esp on a bike I dont want to kill.
Does anyone have any tips, or even a calibration file for a stock bike to raise rev limiter, remove top speed restriction ( I assume it pulls the timing? ) and to do the same adjustments as a TRE does to timing?
I have emailed a USA company to see if they will sell me a calibration but I suddenly thought, will it run the same being an EU model... not sure.
1 - brown
2 - red
5 - blue
6 - black
7 - yellow
8 - green
