Here are some major problems with this write up correct me if wrong but I am not new to this. measuring front shocks while on a back wheel support is a non no I was taught to only measure suspension while both are on the ground infact supporting the rear will change the results of the outcome up front. Also a simple one the special tool they say you need is so you dont scatch everything and or dent it is just professional to use the correct tolls.
When taking your measurement sitting on the bike just have someone keep it from tipping over and someone measure it I was taught this back in the 80's from Kessler himself so I am pretty sure it is importante. Thats it so correct me if I'm wrong.
We need more information. Suspension settings are not 1 size fits all. What is your weight? What do you consider fast? Etc.
You are absolutely correct!
I think Jinkster's thread is how he set up his bike, not necessarily how you should set up yours. It is a good "How to" thread for the beginner. Good illustrations of how it's done!
Andrew Trevitt has a much better detail with photos of the proper way to set up suspension. He also explains why it's done as well as how!
