First and foremost . . .
check ALL terminal connections to the battery power side and the ground side. Look for corrosion and/or loose connections.
If it all checks out OK, next step is . . . .
I strongly suspect you have a faulty battery or a parasitic current drain.
If you are 100% certain the stator output is healthy and regulator/rectifier is also good, next step is . . . . .
Here's a test you can do, it's a parasitic current draw test.
1) Set your digital multi-meter to DC Amps,
2) disconnect the ground terminal from your battery,
3) connect the positive (+) multi-meter terminal to the battery ground cable terminal,
4) then connect the negative (-) multi-meter terminal to the ground terminal on the battery,
5) look at the multi-meter display (digital multi-meter)
6)
if it is drawing more than 50milliamps (.05 Amps) there is an unacceptable drain on the battery from some device in the system.
Have a look at this vid . . . .
