danirlmark
It didn't go down for any reason did it? Tip over sensor could be in play, if that were the case.
Ok so the bike stopped charging completely and all the lights dimmed and bike ran until battery died..fast forward to today and I have replaced stator with new oem unit and also new oem rectifier..found burnt wires for reg/rec on harness side..connectors are bad for stator and reg/rec..at minimum I need new connectors or even a completely new harness..but with everything plugged in I'm getting a crank/no start..not sure what the issue is...all of the 3 wire coming from stator completely Nox Vidmate VLC came out of connector on harness side and I don't know the orientation...they are all 3 yellow wires..I'm frustrated with this poop and I'm almost out of summer smh
