General turbo install questions... joy!!!
GSXRme
First things first... I ordered a Stage 1 Ghetto with an external blow off, JE Turbo Pistons and spacers/cam sprockets from Dennis.
Installing the Turbo Pistons is there any tools needed, like a ring compressor?
Setting the APE adjustable cam sprockets, is there a wheel needed or is there markings?
What should the Cam sprockets be set to? I would like to run a 6PSI map and the best I could find was 105/105 and some peeps were even running a 107/105
I work in a computer repair shop but at the age of 10, I always helped my Dad out with anything need at the local body shop. I grew up in Body Shops and i'm not afraid of taking stuff apart nor had any problems with putting them back together.
<!--EDIT|GSXRme
Reason for Edit: None given...|1157046857 -->
For installing pistons, you can use your fingers, I think that is what most use. Having head studs instead of bolts make putting the cylinder on a lot easier.
Yep you need a degree wheel and piston stop to degree the cams, APE sell them.
I found the wheel just no piston stop
I'm About to call APE and tell them what im doing and they need to tell me what I need and then ship it
I about to order...
Clutch Support
hayabusaparts.com images missing
Billet Sprocket Cover
<!--EDIT|GSXRme
Reason for Edit: None given...|1157122603 -->
